Sound is coming too low
My mobile's volume is high but it can't be hear
좋은 질문입니까?
Hey hi ꧁ঔৣDhᏒuᏉ shᎪᏒmᎪ༻꧂, following are some of the common steps required to solve this very common issue in phones these days:
1) Double check for mute and volume settings
Check again for the sound settings and make sure it is full and your not on mute.
2) Restart your phone
Restarting your phone solves almost 90% of the problems, this might be a temporary issue and you can get it fixed by restarting the phone.
3) Check for stuck headphone jack (🎗️THE MOST HELPFUL🌟 AND 🌟EFECTIVE🎗️)
Plug in your headphone to see if you get sound by the headphones. If you do insert and remove the headphone jack a couple of times rapidly. Sometimes a stuck headphone jack can cut off the speakers.
4) Inspect the headphone jack
Look for any debris inside the headphone jack use a very small object and very carefully clean the headphone jack.
5) Software update
Update your phone and see if it works, sometimes an update is the key?
That's all I can recommend, if none of the above solutions work, then it is probably a hardware issue and you need to get it fixed it a service center. Please let me know if you have some more doubts or queries and also please notify me if any of the above works through the comments section. I will reply you under a week✨ Thanks and have a gorgeous day🌟
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 9
지난 30일: 28
전체 시간: 483
