주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex 790 수리 안내서
Blue screen error problem due to RAM
Blue Screen error problem due to RAM
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @prayag57802,
Did you change/increase the memory?
If so what type and how much memory did you try to install?
Also if you added more memory, does the PC work OK with the original memory that was installed?
의 공유
댓글 달기
답변 1개
@prayag57802 since you are certain this is caused by a bad RAM module, it is time to change it. Of course, you can also try and clean teh contacts first. I use a pencil eraser to clean the contacts. Also, inspect the RAM slots on your motherboard to make sure that there are no bend or corroded pins etc.
To work on your computer use the Dell OptiPlex 790 Desktop Owner's Manual which essentially is the service manual. Now, if you are just guessing that this is a RAM error, then you have to give us more information about what your computer is doing and what you have tried.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Prayag 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 301
