주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Miyoo Mini는 Miyoo가 2021년 12월 2일 출시한 오픈 소스 휴대용 게임기입니다. Miyoo Mini는 매우 작아서 언제 어디서나 주머니에 넣거나 꺼낼 수 있습니다. 기본 가격은 269.00위안입니다.
Why is my screen black
i believe i miss up my miyoo mini it was in miyoo ui and i put a onoin os sd card with an update it install but the screen turn black it turns on i can here sounds still just i can see anything I tried putting the old sd car with ui in it nothing i turned it off and turn it off and on still nothing I know it is dumb but i didnt know this would happen. you think it is fix able
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
This is most likely an software issue.. So if I'm correct, it failed after you've tried to install a firmware update for this device?
If this is the case, the best thing to do is to contact Miyoo. You could replace the motherboard to fix it, but this will be expensive.
Hopefully Miyoo do have something to re-flash the device so that it can be used again instead of replacing the motherboard....
If you are wondering regarding the motherboard replacement, here is a video: https://www.youtube.com/watch?v=6R2h4kfW...
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
This is for the miyoo mini plushic i have the regular small one wh is the miyoo mini not the plus but thank you for your help
의
Hi! My pleasure! Is this the video for your model? https://www.youtube.com/watch?v=97kOOxP3...
Have a nice day!
의
댓글 달기
답변을 추가하세요
Flux 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 43
전체 시간: 1,124
