How to fix the booting loop?
i just reset my phone and then the screen is not changing anymore i try to use the recovery mode but it didnt work
좋은 질문입니까?
좋은 질문입니까?
Hey hi zyro, the only thing I can suggest you at this point is a hard reset.
To do a hard reset, following the given steps:
1) Shutdown your phone
2) Put it in recovery mode (I assume you know it because you saved you tried putting it in recovery mode)
3) Wipe data or just do a factory reset
4) Reboot the system
If Hard reset also does not work then it might be just software update, also try charging the battery for a while (irrespective of it showing a sign of charging or no, just put in the cable, turn on the charger and take it back off after 20mins)before attempting a hard reset.
Thank you for reading and have a gorgeous day =)
이 답변이 도움이 되었나요?
Well I will suggest you to checkout the following video:
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 944
@oldturkey03 the robot got my one of the comment and I am running low now. Please have look at it. Take it back, read it (as it is for you only) and then I will delete it
ᴘʀᴀᴠɪᴛ ʜᴀʀᴤʜ 의 공유
