주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 M5884 / 400 또는 500 MHz G4 프로세서
One of two back from the dead
I have 2 of these. One nice, clean one (case like new, but low spec) bought very cheap last year, to replace the other I have had for years, and looks like it just got back from Afghanistan. I was changing around the memory, keyboard, HD, optical drive. When I finished, both worked fine.
Then I left for 3 months, came back & they were both dead. Really dead. Nothing. Reset button pushed, battery only, adapter only. Nothing. No electrical click or crackles, no response of any kind. Fried logic boards, I decided. Static while changing memory, etc.
3 months later I come back again. One (the Afghan vet with all the bum kit that came with the new guy) suddenly fires up like magic when I press the start button. The new guy with the good stuff remains dead.
What happened? Can I get the new guy to emulate the vet? Or will I have to swap the good stuff back into the Afghan, and look like a hippy again?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 4개
선택된 해법
HI, Using the battery and power block from the one that works reset the pmu (button next to the video out on the back) and try again. If that doesn't work it could be the logic board. Ralph
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
or the pram battery that need to be replaced.
의 공유
Yes it could be the PRAM battery and I would try that before the logic board. Ralph
의 공유
Here's where to get the PRAM battery: http://mac.macrecycling.com/backup-batte...
의 공유
댓글 달기
If you plan to go through batteries like you seem to be doing, I would get one with a two year warranty from Fastmac. http://fastmac.com/laptop.php
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Thanx all
I'll try replacing the PRAM battery. But I'm now wondering abt the OS.
A couple of other machines (Air, Ti Onyx ) have recently shown a tendency to have temporary blackouts, particularly if I leave them on sleep and the battery runs down. They come back after a few forced reboots, but they take their time, and it's scary while it happens.
I don't recall this happening in the old OS9 etc days. Then, you could tell what was happening at startup from the noises, time lag, etc, until the smiley face after the Apple chip had done its checks. OS problems would only show at that time.
So, I'm wondering if OSX might be the problem. Both the 400s are running 10.4. I think the Onyx is on 10.5.
Could this be an OSX bug?..... or a feature?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
How much RAM are you running and how much free hard drive space do you have. I would max the RAM out (RAM is much much cheaper than when this machine came out.10.5 is a pretty heavy system for a G4 500 MHz machine. System 9 had a lot of features that I miss
의 공유
What I really miss is being able to play any of my old games. Of course I still miss Wizardry from my Apple II days. You might want to remove those batteries when on deployment.
의 공유
댓글 달기
Yeah, just when they got OS9 really good (after the 7.5 etc disasters), they pulled it.
RAM is maxed out, & the HD should be OK. I know 10.4 & 5 are heavy, but when it goes it goes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
James doherty 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 27
전체 시간: 1,648
