주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung 넷북 NP-NC10-KA02US는 2008년 11월 15일에 출시되었습니다. 이 컴퓨터는 LED 백라이트 기술을 특징으로 하며, Wi-Fi 및 Bluetooth 연결 기능을 갖추고 있습니다.
Operating system not found
For some days my laptop shows operating system not found I don't know why I searched on YouTube to fix that i even open my bios setup but i doesn't help and then after some time bios setup also not showing on screen i also replace the CMOs battery but it still not showing Could u plsss tell me what should I do...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hey there, I'm wondering if your hard drive might have gone out. Is the drive appearing in your BIOS' boot order?
의 공유
댓글 달기
답변 1개
OP not found is a hard drive issue. However, BIOS not showing might indicate a BIOS issue.
When you turn on a computer, the CPU reads a small piece of code in the BIOS chip. That tells it how to access the hard drive and read the MBR or GPT sectors.
From that info, it can find and load the OS.
Normally, a missing OS would be a HDD fault. Either corruption or a total failure.
Start by trying to do repair install of Windows. Look up how to do that.
if that doesn't work, remove the HDD and connected it to another computer using an external HDD enclosure.
If you can read it, remove all your data - if you do not have a recent backup.
Then reformat the drive and reinstall Windows.
You will have to reinstall all the programs you use also.
Then copy your data back.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dhruwansh dave 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 268
