Why my HP notebook screen in so dim, I need a flash light to see?
Whenever I open my laptop my screen is soo dim, I can't see anything without flashlight.
좋은 질문 입니까?
좋은 질문 입니까?
That usually means the backlight of the display has issues which may require a screen replacement to fix
해당 답변은 도움이 되었습니까?
@amarjeetyadav definitely a bad backlight. this could be caused by failed backlights in your display, which could require you to change the screen. It is also possible that this is caused by a bad backlight IC or even a failed backlight fuse on the motherboard. We will definitely need to know your exact model number. That way we can hopefully point out what and where to test. You will nee to have a few hand tools like a screwdriver set and a multi-meter to make a proper diagnosis without guessing and having to spend extra money.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 22
전체 시간: 22
Hi @amarjeetyadav
What is the full model number and product number of the laptop, as shown on the product information label on the bottom of the laptop?
jayeff 의
