주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
USB-C 충전 케이스를 포함한 AirPods Pro 2는 향상된 방진 기능과 더 빠른 충전 성능을 갖추었으며, Apple Vision Pro에서 무손실 오디오를 사용할 수 있습니다. 또한 적응형 오디오, 대화 인지, 개인 맞춤형 음량 기능을 제공합니다.
Chirping Sounds from Case
Hey guys. Every now and again I wake up and grab my AirPods, and upon moving they begin to make a chirping sound. The light on the case starts flashing (Like Find My) and the sounds are not as loud as those in Find My. Any idea what this could indicate? It chirps for about thirty seconds and then stops once connected to my iPhone.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hello @jadonlyon!
That sound is the sound that AirPods make when they are separated from their owner's device. The idea is if you planted them on someone with the malicious intent to track them, the person would hear the noise every time the AirPods are moved and find them. Obviously, you're not doing that. When it makes the noise, have they been separated from your iPhone for a long time? Is Bluetooth on your iPhone left on? If either of these things have happened, that could be the cause of the noise.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@fixer85785 - Thank you very much! I do typically set my phone in Airplane mode during the night, so that would explain it. I did forget that the AirPods case has the same system as AirTag. Thanks for your help!
의
댓글 달기
Pdffyrtttffffftuvhhvg
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jadon Lyon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 23
지난 7일: 144
지난 30일: 602
전체 시간: 12,984
