주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Super Nintendo Entertainment System(SNES) 또는 줄여서 Super Nintendo는 1990년에 Nintendo에서 출시한 16비트 게임기입니다. Super Nintendo는 당대 최고의 베스트셀러 중 하나였으며 오늘날에도 여전히 많은 팬층을 보유하고 있습니다.
Why does my controller work with only 1 game?
So my SNES will play NCAA basketball just fine on any controller i have. but i put in anything else, the controller only partially works or just the buttons and not the d-pad. for example i put in Super Playaction football and only the A button works. But i put back in NCAA basketball the controller works just fine all buttons and dpad. so i know the controller cant be the cuprit. Any help on this as i love my SNES and want to be able to play it would be super appreciated!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi!
First thing to do is to check the controller port assembly. Please clean it and check for damage. Now, it’s possible that it’s not the controller, but if possible, please check if another controller do work. Just to be sure… also clean the game cartridge slot throughly to check if this one is causing issues..
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
So i cleaned the controller port assembly very thoroughly to no avail. i even have another controller port assembly and tried that too. i have cleaned both controllers and tried them no change there either. all carts have been very thoroughly cleaned as well. ty for your response. im super hopeful someone can help me figure this out.
의
If none of this worked at all, it could be something on the motherboard.. please check that one and also check the IC’s and caps..
의
I'm not sure how to check those. I know what the caps are I don't know what the ics are. But the fact it does play one game ok with no issues how would caps and ics affect this? I'm trying to understand. Ty for your help!
의
@kywildwolf76 it could be that a component failed on the motherboard causing this. Maybe that game is not using a particular component. You can check with the multimeter if they are fine or not. Please let us know if you need some more info!
의
i have a multimeter but im not sure what im supposed to be checking or what parameters anything is supposed to fall within
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Kywildwolf76 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 420
