주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jura의 소형 머신입니다. 모델은 다양하지만 수리 방법은 거의 동일합니다.
Machine keeps saying press rinse
Machine says press rinse repeatedly
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
When you rinse, does water come out? So my first idea is the flowmeter. Is it perhaps clogged and therefore not reporting any water flow to the electronics? Open the machine. Step 12, first picture shows the flowmeter, the small white round box next to the brewing unit. Open it and clean it, as described e.g.here.
Jura ENA micro 9 이미지
안내서
Jura ENA micro 9 분해
난이도:
조정
Jura Impressa S85 유량계 이미지
안내서
Jura Impressa S 모델 유량계(Flowmeter) 교체/점검
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
This totally saved my Jura from sending it in for repairs thank you so much although what happened was I did everything,cleaned it put it back together and it still kept saying rinse. I reversed the tubes because I wasn’t sure if I put them incorrect and tried it a few more times it kept saying the same thing so I figured I was going to send it in but then I reverse them back again to the proper way and now it works like a charm. Maybe it just needed to unclog something and the reversing of the tubes did that. in any event thank you very much.
의
@kimwoodbridge So the flowmeter - as often - was the culprit. The channel where the water flows in is very narrow, for sure it was clogged. Congratulation to your repair!
의
댓글 달기
답변을 추가하세요
John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 86
전체 시간: 1,172
