주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
EF 600mm f/4L USM 렌즈의 후속으로 Canon이 1999년 9월에 출시한 슈퍼 망원 렌즈입니다.
How does this ribbon cable connector open?
To replace a switch plate on this Canon Lens, I need to remove the ribbon cable from the brown and white connector in the lens.
This type of connector is probably used in other electronic equipment so even if you have not disassembled a lens, you may know how to open this connector.
Photo 1 shows the ribbon cable of the part I need to remove locked into the brown and white connector.
이미지
Photo 2 shows a side view of the brown and white connector.
이미지
How does this ribbon cable connector open? Does the brown part slide down in photo 1 toward the ribbon cable or does the bottom edge of the brown part lift up to release the ribbon cable?
Photo 3 show the new switch plate with the attached ribbon cable.
이미지
Photo 4 shows the new ribbon cable with the conductors exposed near the end.
이미지
The lens was first sold in September 1999 so the connector is of that vintage.
Canon said there where no instructions available when I ordered the part.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The bottom edge of the brown part of the connector in Photo 1 above lifts up to release the ribbon cable.
Here is what the connector looks like in the open state with the ribbon cable removed.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
John Rosford 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 263
