주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 11월에 출시된 Sony의 슬림형 PlayStation 5 리프레시 모델에 대한 수리, 분해 및 문제해결 정보입니다. PS5 Slim으로 불리는 이 기기는 1 TB의 표준 저장 용량과 모듈형 디스크 드라이브를 탑재했습니다.
Is there a Bluetooth antenna?
Hello! Looking to upgrade the antenna for the Bluetooth (better controller range when ps5 is stored inside a rack).
Wondering if the blue and white cable shown in the teardown video is the Bluetooth antenna
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
@eddietsang have you tried the Bluetooth mod yet and have you been successful at it? Iam looking to do the same with my ps5 slim.
댓글 달기
답변 1개
가장 유용한 답변
Hi Eddie!
The blue and white antenna cables are basically fused together on some metal (and this one is attached to the PSU).
Here you can see where it comes together (the part): https://www.ebay.com/itm/196416264711?no...
Those are for the WiFi and Bluetooth together.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Ooh I see. Can you explain what you mean by "this one is attached to the PSU"?
The antenna on eBay you referenced is the exact one I see after opening up my Slim. I installed an external antenna in place of this... So to confirm, are you saying the Slim only has one antenna(wifi and Bluetooth together) as opposed to 2 in the original ps5?
Thank you
Hi Eddie!
The metal piece is attached to the power supply! But this is only for the PS5. For the PS5 Slim it’s attached to the the side (opposite site from the power supply). Yes! The original PS5 have 2 antenna’s. blue and white, and black and white. The PS5 Slim only have the Blue and White ones. Wifi and bluetooth are combined. Same for the original PS5, but do have an extra antenna for more range.
And so can we just pull the blue cable an attach an external 2.4 antenna (say 6db ?)
댓글 달기
답변을 추가하세요
Eddie Tsang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 58
전체 시간: 1,828
