주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PIXMA G3010은 2018년 초에 출시된 올인원 무선 MegaTank 프린터입니다. 인쇄, 스캔, 복사 기능을 지원하며 내장 Wi-Fi와 무선 다이렉트 연결을 통해 간편한 모바일 인쇄가 가능합니다.
How to fix P22 error
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
How to fix p03 error
의 공유
댓글 달기
답변 2개
가장 유용한 답변
P22 is a somewhat vague error :-(. It's a mechanical error in this case, but a lot of the time it's a damaged scanner. SOMETIMES it can be fixed by reseating the scanner cables. I don't have a G3010 to show the process on, but I did find a video that shows how to open the unit up and check the cables.
If reseating the cables does not help, you will need to replace the scanner assembly. Canon does not directly sell parts for ANYTHING they sell, so you need to go through a 3rd party to get the part if it is even available. Given this is an inkjet and the CISS inkjets are just more expensive disposable hardware (whereas cartridge-based units were cheap, but ink was expensive), parts may not be readily available. Your best bet would be getting a donor printer with the infamous 5B00 error (commonly used waste ink error code, which might vary) to get the part off. I say this because you can't fix that issue without rerouting the waste ink or a full teardown and making an absolute mess, so nobody wants to do it; 5B00 and it's equivalents are a death sentence. But this also means anything outside of the controller board and pads is fair game to pull as long as it doesn't hold waste ink.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try resetting the printer, cleaning/reconnecting the scanner cable, or replacing the scanner unit.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
please input auth code to unlock
의 공유
댓글 달기
답변을 추가하세요
Yatogami 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 28
지난 30일: 118
전체 시간: 2,941
