주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 6월에 출시된 Casio의 공학용 계산기입니다. Classwiz 기술을 사용하며 시험용으로 널리 쓰입니다.
keypad does not work properly
  • key 2 and key 1 both work as 1
  • key 4 and key 5 both work as 4
  • key 7 and key 8 both work as 7
  • key STO and key ENG both work as STO
  • key ((-)) and key (.,") both work as ((-))
  • key STO and key ENG both work as ENG
이미지
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Physical keypads and keyboards work on a matrix principle; you have a series of wires going horizontally and a series going vertically, and pressing the button shorts them together, which the keyboard controller then uses to detect a keypress and knows which one it is. Here's a drawing showing what I mean.
이미지
In your case the two vertical lines supporting the first two columns of buttons on your calculator have somehow gotten shorted together, so anything being pressed in the second column is being detected as being in the first column.
About all you can do is open up the calculator and look at the circuit board or flex that the buttons are connected to. Trace out the first two columns and see if you can find a spot that is either damaged or corroded and somehow bridging the circuit traces together.
If you can open it up and take some high resolution pictures of that circuit board, we'll be happy to take a look and try and help diagnose where the issue might be.
Adding images to an existing question - iFixit Repair Guide
Good luck; take a look and let us know what you find.
Update:
It appears the signals from the keypad matrix are coming into the main circuit board via that flex cable mounted on the top of the board.
이미지
I can't see any obvious issue with that part, so unfortunately the only way you're going to be able to find the problem is to cut or melt those retaining pins off. I assume it's the six spots within the larger white circles that are what's holding the circuit board in place. I hate it when they do that; they're just assuming no one is ever going to want to actually repair their product.
So yeah, the only thing you can do at this point is to get that circuit board off so we can see the flex cable supporting the keypad.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I add the images from one side but, other side can not open without breaking plastic lock.
의 공유
댓글 달기
Similar type problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lekamalage lahiru chinthaka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 96
전체 시간: 1,103
