Blower Exhaust Fan Inoperable
My Mac Pro 2019 exhaust blower fan does not operate anymore.. It started as noticing that the front system fans (the 3 fan stack) were running more often than usual. In Macs Fan Control, the RPM then started reading 0 RPM on the Exhaust fan and I cannot control the speed through Macs Fan Control. Then recently (after the service I will mention), the blower fan makes some bad grinding noises on boot, only to turn off and stay off.
I had this machine in Apple Green Hills Nashville for service, where they said they replaced the blower assembly with a new one, but the fan still did not spin. They wanted to do more work on it, but it would be $1300 and more time, which I declined.
I'm posting this simply because I have yet to see anyone with this same issue on the internet. I have ordered a used blower assembly from eBay to see if I can get a different result than my local Apple techs.
I'm currently running Monterey 12.7.5 and will probably be upgrading the computer if replacing the assembly does not fix the issue. I'm hoping a firmware update might help me.
I will update this thread as I try and resolve this issue.
좋은 질문입니까?
This system has gang of three fans in the front and one within the power supply. Which fan are you having issues with?
DanJ 의 공유
https://guide-images.cdn.ifixit.com/igi/...
This one.
Matt Rausch 의 공유
@mattrausch you most likely do not need a part number for the blower fan (you've already ordered one ;-) but just in case, it is Apple part number 923-03328 and available at many places. Let us know what happens when you install the new blower. The things you do want to check are the contact springs. Make sure they line up etc. and are not damaged or not properly seated from the previous service.
oldturkey03 의 공유
@oldturkey03 This is tremendous info, thank you so much. I had seen a part no for the M Series Mac Pro (923-08647), but I didn’t see the Intel part number available anywhere before your comment!
Matt Rausch 의 공유
@mattrausch glad I could help. Just keep us informed once you get your new fan. I really hope it is the fan and nothing worse :-)
oldturkey03 의 공유
댓글 3개 더보기
