주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
천장에 설치된 날개형 선풍기에 대한 수리 및 지원 정보입니다.
Matching up replacement capacitor
The capacitor in the top pic needs to be replaced. Can I replace it with the capacitor in the bottom pic? I know from reading other posts that the higher voltage on the red wire is fine, but I'm wondering about the configuration of the wires. The green and brown wires have the same rating in both, but are in reverse locations. The gray wires are in slightly different locations relative to the other wires too. I don't know if this matters. Thanks for your help!
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi Rob,
You've got good instincts here; the second capacitor will indeed substitute for the original one just fine.
And yes, when you're wiring it up, ignore the positions of the wires coming out of the device and wire it strictly according to the colors of the wires. The two grey wires are actually wired together so it doesn't matter which one goes where, as long as it's gray. For the others, stick to the original wiring colors; red to red, green to green and brown to brown (or wherever each of these is connected on the original).
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks very much Jerry!
의 공유
댓글 달기
답변을 추가하세요
Rob D 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 47
전체 시간: 975
