주요 콘텐츠로 건너뛰기
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 질문 전체 보기
iPad 3rd Gen Digitizer the same as 2nd Gen?
Can I install a 2nd Gen iPad Digitizer into a the new 3rd Gen iPad?
If so, is it an identical match?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Was wondering the same thing. I want to get a color conversion for mine but all of the ones I've found have been iPad 2's...
I checked my ipad imei and said it was an ipad 3G. My touch screen was cracked so i need to replace it. The question i have no see ipad 3G it always ipad 3 in selling touch screen. Can i buy ipad 3 touch screen to my ipad 3G it will work? Please help me.
no they are different
댓글 달기
답변 10개
선택된 답변
They appear to be different parts (iPad 2 digitizer, iPad 3 digitizer).
That said, I've scrutinized the photos from the iFixit teardowns of both the iPad 2 and iPad 3, and darned if I can see any significant differences. The metal shield around the camera appears to have grown a spring-contact on the iPad 3 to improve contact with whatever it touches, but that looks like it. And it would be very in keeping for Apple to use the same part for both iPad 2 and 3 if they function the same way. The logic boards of each of the two even have their various connectors to the screen and speaker arrays in the same spot.
So: inconclusive. Maybe we'll luck out and an iFixit staffer will compare and contrast the parts for us.
iPad 2 Screen Digitizer 이미지
상품
$24.99
iPad 3/4 Screen Digitizer 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thank you. It would be nice of iFixit to that ;)
댓글 달기
가장 유용한 답변
The board sockets (connectors) are the same. The iPad 3 digitizer cable is longer though. So, as stated above, you can use the iPad 3 diggie on an iPad 2 with a couple of folds on the longer cable. However, you wouldn't be able to use an iPad 2 diggie on an iPad 3. The cable just isn't long enough.
IndyElectronix
해당 답변은 도움이 되었습니까?
점수 6
댓글 달기
I just replaced an iPad 2 digitizer with an iPad 3 digitizer. Although the flex cable is different in length, it still fits the mainboard connector and has a couple of extra folds that got tucked under the screen, as far as I can tell, it works.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Mark Richard,
Please let me know, after you replaced it and completed every thing, did the digitizer looked fit on the ipad?? or there was some kind of problems??
댓글 달기
iPad 2 digitizer does not fit iPad 3 the flex cable is totally different.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
see above you just repeated what he said lol
댓글 달기
I believe the connector is in a different location. I'll be doing one in about 2 weeks and can update as I have the iPad 2 in stock.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I would not do it. The ribbon cable is longer and is at a different angle. See photo...
This can result in a problem sealing the screen...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Will a ipad 2 digitizer fit a ipad 1?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Not a chance. Different size and design.
I want the other way around. I have an IPad1 in pristine condition and my daughter IPad2 glass screen has a big crack. Can I swapped it out from Ipad1 to Ipad2 since my Ipad 1 is just a glorified wall clock?
iPad 1 and 2 are too different. Better buy a new third part digitizer for the iPad 2.
댓글 달기
What about the lcd would a 3 fit a 2 and other way around?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
An iPad 3 LCD will not fit an iPad 2 at all the connector is different: 3 has a ZIF socket and 2 has a metal connector with a metal clip and 3 is a retina display these are incompatible.
댓글 달기
I just replaced a white iPad 2 screen with a black screen replacement and there seems to be a noticeable difference in the screen size. It doesn't quite fill the frame. Did I get the wrong screen ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Use the iPad 3/4 touchscreen, just fold the flex cable and tuck it under the LCD, make sure you don't tear it or rip it. it will work. I been doing this for years. The camera bracket is different, just swap it for the broken one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MacBroke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 38
전체 시간: 26,938
