주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 iPhone SE는 3월 9일 (미국 시간 3월 8일) 신제품 출시 행사 Peek Performance Apple에서 소개되었습니다. A15 칩과 4.7인치 LCD 디스플레이가 특징입니다.
Replaced screen but not working
Old screen now not working either
All connectors look fine
Please help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
So after doing some googling it was as simple as doing a reset, it has now sprung into life.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Awesome, Justin; glad to hear it was something simple.
의
댓글 달기
가장 유용한 답변
Hi Justin,
You've got an iPhone with a screen made with older LCD technology, which means it has a backlight. It would be worth your time to check to see if the backlight has failed. Take a flashlight and hold it up against the screen and see if you can make out an image. If so, you may have blown a backlight fuse on the motherboard, which would be a tricky repair for us home DIY-ers. That sort of thing usually happens when the screen is connected or disconnected while the battery is plugged in; it rarely is a problem when the battery is disconnected before working on the screen.
Check that out and let us know what you find.
Does the phone appear to be alive in other respects? Does it make any sounds or vibrations when turned on or connected to a charger? Is there a response when plugged into a computer; does the computer recognize that it's there?
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for your help, but all it needed was a reset.
의
댓글 달기
답변을 추가하세요
Justin Short 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 35
전체 시간: 482
