주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One X(모델 1787)는 Xbox One S의 후속작으로, Microsoft의 고성능 게임기입니다. Xbox One X는 2017년 11월 7일에 출시되었습니다.
Power button light not working
The light on my on/off button doesn't light up on my xbox one x gold rush edition the console starts up fine and works perfectly any ideas why the light won't work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi Tom!
Most of the time it's either the PSU or the motherboard.
I would try a new PSU first! You can buy a replacement PSU and try it. If this didn't solved it, then return it and get yourself a refund.
Could also be the front circuit board. Does the Xbox power on with the controller?
I would try a new PSU first.
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
Yes the console powers on with the controller
의 공유
Alright, this changes it. Then it's probably the switch which is faulty. The PSU and motherboard should be fine. Please try a new front circuit board first. This will most likely solve it. This is the one you need: https://www.amazon.com/Internal-Circuit-...
의 공유
The console is a xbox one x by the way
의 공유
Yes, the part in the link I've sent is for the Xbox One X :)!
의 공유
Thank you for the help hopefully I can fix it
의 공유
댓글 3개 더보기
댓글 달기
답변을 추가하세요
Tom Bowden 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 575
