주요 콘텐츠로 건너뛰기
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
20 질문 전체 보기
Why is the phone's battery taking longer time to fully charge
How can i fix a phone who's battery is taking too long time to fully charge despite having a new charging base?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
There’s a few different reason why a battery would take longer to charge:
1: Could be the charger cable/brick/outlet going bad. Try using a different cable or brick and see if that improves. If you any damage or bent pins on the charger this is probably why it’s going slower.
2: Bad/dirty charge port on the phone. Dirt and dust can sometimes get lodged inside, especially if you keep your phone in your pocket. Turning the phone off and blowing some compressed air in the port can get the debris out (be sure to hold the can upright). You can also use some isopropyl alcohol (the higher the percentage the better) and a toothpick/tweezers to clean the port out. Just be careful not to damage the connector inside (Micro-USB is very delicate).
3: Bad battery. Could just be the battery going bad and needing to be replaced, common older devices.
Personally I’d try cleaning the charge port out first, then trying a different cable. In my experience it’s usually the charge port. 😊
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ellard Mitunda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 22
