주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 10월에 Google에서 출시한 3세대 Pixel입니다.
How to clean charging
There is dirt in the shipment and I cannot install it USB How can the problem be solved?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If there is dirt stuck in a usb port, what I have personally found to work is to get a toothpick (preferably plastic) or similar (Something that is sturdy enough and won't break apart or leave more fluff inside) and carefully scoop it out.
I usually use a disposable plastic toothpick/floss and stick the toothpick end in to pull dirt out.
For safety, make sure it is not powered at all. If it is a device like a phone, then power it off just in case. And if the port has any visible pins, be extra careful not to damage them.
I am keeping my answer non-device-specific as it should work for any type of USB port and device. (I know original question is about a pixel phone and I have done this solution many times with my phones that have USB C ports to remove dirt, paper etc.)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ahmed ali 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 284
