Doesn't sound good
it doesn't sound good when I talk on the mobile phone (it sounds good on whatsaap or viber)?
좋은 질문입니까?
좋은 질문입니까?
@nikollatesla since it works well in some App's but not in others, this would most likely be a software issue. Make sure that all the settings are properly set in regards to the Audio First thing to do would be to start your phone in safe mode. Safe Mode puts your phone into a diagnostic state (returned to default settings) so you can determine if a third-party app is causing your issues.
Press and hold the Power button until the 'Power off' prompt appears on the screen then release.
Touch and hold Power off until the 'Safe mode' prompt appears then release.
To confirm, tap Safe mode
With Safe Mode enabled, ensure Airplane Mode is turned off then test your App's for sound. from here
If you do have decent sound in safe mode, you know that it is one of the third-party app that is causing those issues. For that you would have to delete those downloaded Apps one after the next until you delete the bad one.
Should you still have no sound or bad sound in safe mode, try to see if you can run the hardware diagnostics on your Samsung. Dial *#0*# and see if you can now see Hardware Test Mode. If so, you see a Speaker item. Run the test for the Speaker and see if it passes or fails. If it fails, it's hardware and most likely requires a speaker replacement.
Since iFixit does not yet have a specific guide for this, use something like this guide It was written in Spanish, so use a browser that will do the translation for you. Replacement speakers are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 209
