주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP E1000은 Sony에서 설계한 휴대용 게임기입니다. PSP Street로도 알려진 이 보급형 PlayStation Portable은 2011년 10월에 출시되었습니다.
Is my device bricked?
So, I was opening my PSP Street wide to get something stuck in the SD slot out, and I unplugged the LCD: And when I put it back the video output was fine at first but after some on/off it showed a white screen. I tried unplugging it and plugging it back and turns out I plugged it in loosely. However after a very short duration the screen gradually turned white, so I plugged it out.
Next thing I know the PSP has turned off and not only the battery stopped working altogether, but the display didn't show anything anymore.
Is it bricked? or can I somehow, by a miracle, fix it?
EDIT: Turns out the battery is fine, I somehow managed to plug it in in a way that it unplugs itself when I put the lid back on and pick the device up. 🤦‍♂️
Anyways, the screen remains an issue. I can see it changing brightness very slightly when I turn on the PSP, and nothing on the display itself seems damaged; But it shows a completely black screen. I've tried to shine a bright flashlight on it, but not much of a signal can be seen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi! White screens usually indicates that the cable isn’t connected properly or is damaged. Won’t your PSP not turning on anymore?? Or does it turn on at the moment?
Update (08/10/24)
Yeah, you probably need a new screen. The ribbon cable is probably damaged. I would try this first and see how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
Turns out, the battery was just loosely plugged in. it can actually turn on without AC, but that still doesn't fix the screen issue. It's completely black, but it actually turns on and I can see it slightly changing brightness. I don't know if the display is fried or the device is bricked.
의 공유
I probably can't get an exact replacement, what are the general specs I'm looking for?
의 공유
Hi!
You need this one: https://www.aliexpress.com/i/10050052268...
They do ship worldwide!
의 공유
@dan0 "This item is no longer available".
의 공유
Then you need this one: https://www.googleadservices.com/pagead/...
The screen is expensive :(.
의 공유
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Zero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 38
전체 시간: 1,033
