주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Raspberry Pi 4는 Raspberry Pi 재단에서 개발한 다목적 싱글 보드 컴퓨터로, Raspberry Pi 제품군의 네 번째 모델입니다.
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
의
댓글 달기
답변을 추가하세요
in_sympathy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 80
전체 시간: 1,109
