주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi 7은 2019년 3월에 출시된 Xiaomi의 저가형 스마트폰입니다. 6.26인치 IPS LCD 디스플레이, 12MP 후면 카메라, 후면 지문인식 센서, 4000mAh 배터리를 탑재했으며 Snapdragon 632 프로세서로 구동됩니다.
How to attach detached screen from back side
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
First thing to try is putting it face down on a towel or something soft. Get some heavy books close to hand. Use a hair dryer to heat up the area well. Keep it moving around the area . Then quickly put some heavy books on top and leave for a bit it might reactivate the adhesive. Or 2 put elastic bands tightly around to hold it where it should be then heat up with a hairdryer. If those options don’t work. Then you’ll need to either replace the back panel adhesive or just replace the entire back panel altogether as it will come with new adhesive attached.
Adhesive link
https://www.aliexpress.com/item/10050068...
Rear back panel with adhesive
https://www.ebay.co.uk/itm/165516620331?....
Back removal guide
Xiaomi Redmi.
Lastly you could bodge it by putting glue in the gap carefully. Not recommended.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If you mean the screen itself is coming away. Follow this guide and when the screen is out replace the screen adhesive with what’s linked in the guide.
Xiaomi Redmi Note 7 스크린 교체
의 공유
댓글 달기
답변을 추가하세요
somduttt sharma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 355
