주요 콘텐츠로 건너뛰기
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 질문 전체 보기
질문 마감됨
Moding my xbox with a clear case.
Hello.
i am putting a clear case on my Xbox 360 s console and i wanted to no do i need the thin aluminum sheet attached to the plastic on the inside of the case. It blocks a lot and kinda destroys the idea of a clear case..please answer
-Kaine
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thank you and i have seen them ran without just so you can see inside them?Any thought about this??
댓글 달기
답변 1개
선택된 답변
kaine, there is a lot of sheet metal attached. I would think that this is responsible for airflow, EMI shielding, and possible structural stiffness. It might even provide a common ground. I guess you can always try to run your xbox without it and see if it overheats, and if you will have interference from, and to, other electronic components. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+1. Also, I take the mod case comes from a reputable source. They usually add a manual, telling whick parts salvage from the old case and which keep.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 844
