주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon의 Kindle Paperwhite 시리즈 중 이 버전은 2015년 6월 30일에 출시되었습니다. Kindle Paperwhite 3세대는 Wi-Fi가 가능한 6인치 300 PPI 읽기 전용 디스플레이 태블릿입니다. 지정된 모델 번호는 DP75SDI입니다.
My screen is stuck at language setup screen.
Hi Team,
My Kindle was stuck all the time on home screen.
When I press power button it would popup option to restart, shutdown cancel however I was never able to select it.
Out of frustration I followed an article on Internet "Doing Factory reset using computer"
I created File without extension Do_Factory_Restore transferred to kindle performed factory reset.
Now my screen is stuck at language setup page.
  • I am unable to select get started 😑
  • I tried pressing hardreset for 40sec no joy.
  • I tried connecting kindle to computer it shows drive is not ready😓.
  • I have put my self in helpless situation.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Is the touch screen working? It could be a screen issue.
Touch works on limited area rest feels like screen Is dead
It’s possible half the screen is dead , most probable in-fact as it’s a strange screen to be stuck on. Have you dropped it any marks or damage on or around the screen? I’m weirdly convinced my below answer will fix this.
If your not confident you could always take it to a repair shop for second opinion/ repair.
댓글 달기
답변 2개
If you cannot do anything on the screen it is most likely a damaged digitiser. This can get damaged by a short fall or bump in the wrong place . Here’s a full guide and what to get.
Kindle Paperwhite 3세대 스크린/디스플레이 터치 패널 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try to turn off the screen using the power button and long-press it for a few seconds. If this doesn't work then try charging it for sometime. Restart your Kindle to resolve the frozen issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ashley John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 9
전체 시간: 329
