주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색. 이 페이지는 사용자가 iPhone 4 문제를 진단하고, 수리하고, 도움을 받을 수 있도록 돕는 것을 목표로 합니다.
Enter a passcode on a disabled iPhone 4 on iOS 5
I have an iPhone 4 GSM on iOS 5.1.1 that I would like to recover the data on. It is disabled and says to connect to iTunes but I know the passcode and want to enter it. The passcode is 0209 if that helps. I just want to recover some old data on it and do not want to restore and update it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
The assumption that I know how to connect via SFTP is false. I have no idea how to. Could you try to find a video tutorial? I do have a 64-bit Windows 7 Computer with iTunes 12.0.1 I think. I will install it and see if it works. I previously tried to use Gecko Toolkit which is how I got the passcode but when I tried the disabled bypass it said Ignoring Unsupported Device UNNSUPPORTED in big red letters. Maybe it’s my Java or iTunes version not being right
의
댓글 달기
답변 1개
Hi, this is some old school issue it was/ is possible.
for the life of me I can’t remember how.
I know it could be done before ios 7.
Here’s something referring to it.
https://www.reddit.com/r/setupapp/commen...
The iTunes version is critical newer versions won’t work. Windows OS not sure?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lennon Ford 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 472
