주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
16.2 MP Exmor R CMOS 디지털 스틸 카메라(3.5인치 OLED 터치스크린, 3D 스윕 파노라마, 풀 HD 1080/60p 동영상 지원, 블랙) 출시일: 2011년 1월 12일
Why is my camera don't on while charging
My camera don't on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@harsh56452 first you want to check your AC adapter. Make sure it has the proper voltage. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If all of that checks out, you do want to go ahead and replace the battery. A depleted battery can no longer be charged and can possibly prevent the camera from coming on.
After that you will have to disassemble your camera and check the power circuitry on your camera. On your cameras SY-280 board are two fuses, marked F051 and F051. Those are the power supply fuses. Check those for continuity. If they have failed, your camera will not come on.
이미지
이미지
이미지
You can now get the service manual on the bottom of this page Sony Cyber-shot DSC-TX100V Check under documents.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Harsh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 236
