주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook 840 G4는 업무용으로 제작된 세련된 14형 노트북입니다. Intel 7세대 Core 프로세서로 구동되며, 슬림한 알루미늄 본체와 비즈니스 환경을 위한 강력한 보안 기능을 갖추고 있습니다.
My battery died fast
my laptop battery died fast and its just charge for 80% and its died also when it close
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi,
Your laptop has been around since 2008 and I would suggest it has already had a battery replacement at some time in the past.
Depending on when it was last replaced, it’s more than likely the current battery is no longer capable of taking full charge or holding charge any longer.
If you have more recently replaced the battery it’s possible that it wasn’t a good quality battery or has developed an internal issue that affected its ability to perform as it should.
The other thing you may need to check is the charging power supply, as it may no longer provide enough charge voltage or current due to fatigue or cable damage.
You could try another charging plug pack & cable if you have access to one.
You may need to either have the charge pack & cable & battery tested at a repair shop.
Or if you know the battery hasn’t been replaced for a long time and your charging pack is functioning properly, buy a replacement battery.
Hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mohammad Khair Al-Sairafi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 226
