주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
How to change front glass lens
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
It's one of those if you need to ask, you can't do type of operation.
If you insist, here is the general breakdown:
  • Remove the screen assembly from the phone and remove critcial parts like the home button, ALS/top speaker flex and so on.
  • Cut open the plastic screen frame and pull it off the glass.
  • Use thin molybdenum wire to cut through the LCD optical bonding to the panel so you can separate the panel from the glass.
  • Use solvents to wash the remaining optical bonding from the LCD panel.
  • Apply new optical bonding adhesive to the LCD panel.
  • Attach the LCD to the new glass panel, align it properly and avoid trapping any debris between the bonding.
  • Use a vaccum lamination machine to properly bond the optical bonding layer to remove any air bubbles.
  • Adhere a new set of screen frame onto the glass.
  • Reassemble critical parts and the whole phone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Basil Kurian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 68
