주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amana 냉장고는 아이오와주 Amana에 위치한 Whirlpool Corp 그룹에서 제조합니다.
Freezer not freezing sufficiently
Amana bottom freezer fridge.(XRBS017BW)
Freezer cannot maintain sufficient minus degrees....thus fridge is also too warm.
Compressor running frequently
Door seals OK
Condenser coils clean
Refrigerant OK
Thermostat in freezer changed
What could be the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I can add that the fridge has been unpowered for 18 hrs to melt any ice.
A quick reset has been tried.
Compressor starts when temperature dial is tapped a little hard..
의
댓글 달기
답변 1개
What is the frig temp? How old is the unit?
A few possibilities:
Defrost cycle stuck leaving the heaters on
Something internally blocking the system copper lines
A problem with the filter/dryer (part of the system that may be causing above)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Freezer temp: -6 - -8'C
Fridge : + 9'C
Refrigerant is presently double of recommended amount to try help on the temps.
Please note that compressor oftently starts when temp dial in freezer is tapped
의
댓글 달기
답변을 추가하세요
Mikael 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 212
