주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
My problem is at Step 3
My problem is at Step 3, when I press the power button, the LED 2 lights up but when I leave the power button it turns off and the system also does not turn on. I have followed all the other steps after that and still nothing. Please suggest/help.
Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What happened with your system?
Hey there, Step 3 of what guide?
댓글 달기
답변 1개
가장 유용한 답변
Without more information it's hard to be certain what's gone wrong, but if you're only getting the first two diagnostic LEDs, then you may have an issue with the video card (something that is known to fail on the 2010 model). If the system is powering off immediately after releasing the power button, though, then that may indicate some larger issue, either with the power supply or the main logic board. Good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dharmesh Thakker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 177
