주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004년 9월 Sony에서 출시한 더 작고, 얇고, 조용한 PlayStation 2(SCPH-700xx) 모델입니다.
Loud buzzing only when the top shell is on
The disc reads and boots fine when the top shell is off and I'm manually pressing the eject detection button things but when I put the top shell on, it makes a loud buzzing and doesn't read. I think the buzzing is the laser linear motor not stopping and I have no clue why. I imagine I need a new shell, just seeing if there's anything else I can do. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Figured it out, I 3d printed out some parts to push the DVD laser ribbon cable down so it wouldn't scratch the disc and a screw holding down one of the parts was lifted enough to be touching the top shell so when the laser assembly moved, the screw was scratching the top shell causing the noise. To fix it I'm just cutting a bit of the shell off as the screw is close to the main cutout for the laser.
If you're having a similar issue, put the top shell on with no screws and see if the laser is hard to move back and fourth especially when adding pressure to the top. Also look at the underside of the shell for any scratch marks.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I will say please DO NOT CUT YOUR SHELL if you have other options, you might make your problem worse and scratch the disc badly. Proceed with caution if you do this.
의
댓글 달기
가장 유용한 답변
Hi Jek!
Is it possible for you to make a video for us?
It's also possible that the disc is actually grinding to the shell (when it's spinning).
Are you sure that the top cover is 100% seated correctly and all the screws are in (just to be sure)?
Otherwise you can check for a new top cover and see if that solves it.
As it does work with the top cover off, the components should be OK.
Since when is this happening? Just out of nowhere? Or did you do a repair before it happened?
Please let us know!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 333
