주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anywhere Mouse MX는 Logitech에서 2009년에 출시한 레이저 마우스입니다. 이 마우스는 Logitech Unifying 수신기를 통해 연결되며 AA 배터리 2개가 전원을 공급합니다.
I have broken a pad SW1 (again)
Hello!
I have broken my second Anywhere MX 1 mouse when replacing the SW1. The pad broke again near R6 (signal one, the ground is fine) and I was certain to not break it again. But it happened.
Is there any chance that anyone has got the schema or idea where the signal comes from? I would love to make a jumper and get my favorite mouse to work.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
is this copper, can't tell with the flux
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I've edited my post and added photos of front and back. I've checked the C6, which appeared to be connected through a hole, but that side od capacitor appears to be a GND.
의
Nope - it is a PCB. The pad fell off. The only thing that is copper is the little hair trace that's left.
의
@makerbuddy have you got a multimeter
의
Yes I do, so I could tell that the trace goes to ground.
Besides I was working on it and today managed to catch the copper trace that was left from the pad. Used some copper wick as a new pad and everything works fine.
Besides that I still did not got idea where it goes! I've checked every component and signal points, but none of them was giving a beep in continuity test with multimeter...
의
댓글 달기
답변을 추가하세요
MakerBuddy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 328
