주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Products에서 제조한 스마트폰에 대한 수리 안내서 및 지원 정보입니다. BLU는 'Bold Like Us(우리처럼 대담하게)'의 약자입니다.
Screen seperated from the phone
I have the F91 5g and the screen came out of the phone I don't see where the screen is supposed to connect back into the phone. Does anyone have pictures to show how this is supposed to be reassembled? I see what appears to be where the cable connects through the system however I don't see a connector there.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi Jason! For your F91 5G, Here are some you can follow:
  1. Check for screws: Make sure there are no screws or clips holding the screen in place. Sometimes these can be hidden under stickers or rubber pads.
  2. Locate the connector: The screen should have a flex cable that connects to the motherboard. Look closely at the area near the battery or main chip; it may be under a small cover or bracket that needs to be removed.
  3. Use a magnifying glass: If the connector is small or difficult to see, a magnifying glass can help you locate it better.
  4. Consult repair guides: iFixit often has detailed guides with pictures for disassembling and reassembling specific phone models. This might give you a clearer idea of how the screen connects.
  5. YouTube videos: Search for disassembly videos specific to the F91 5G. Visual demonstrations can be incredibly helpful.
  6. Avoid forcing connections: If you don’t see an obvious place for the connector, double-check that you have the correct screen and that it hasn’t been damaged.
  7. Happy Fixing!
(Formatted by Ai for easy reading. Never written)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jason Howell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 167
