주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 5월에 출시된 Apple iPod Touch의 7번째 모델입니다. 최대 256GB 저장 용량과 A10 프로세서가 탑재되어 있습니다. 모델 번호 A2178.
Battery removal is never mentioned
In all of the answers after step 22 -all the guides instruct to set aside the battery to the left. None of them say actually how to remove the battery in full.
How it is done? Thanks all- I just need to service the battery.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
The battery is soldered to th logic board, so you’ll need to have some basic command of soldering to remove it and replace with a new one.
If you have a look at the battery, it’s not like the other components that have a connector which snaps into something on the board. There is some tape covering the contacts on the board. You’ll need to desolder the connector here and solder on a new battery.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V). 이미지
제품
iPod touch (6th and 7th Gen) Battery
$19.99
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thanks- Fix-ability of this product seems low- I might not tackle it.
댓글 달기
답변을 추가하세요
Paolo Alberto 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 43
전체 시간: 493
