주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 5월에 출시된 13" MacBook Pro는 쿼드 코어 8세대 Intel Core i5 및 i7 프로세서, Intel Iris Plus 645 통합 그래픽을 탑재했습니다. (썬더볼트 3 포트 2개가 있는 모델 A2289/EMC3456)
How do I replace the camera?
My camera is not working, can someone explain how to replace it please. The green light comes on but no image
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 8개:
Not sure what happened. I posted an answer here and I was notified that you commented on my answer. However, my answer is nowhere to be found now.
의 공유
@wenchao - It was deleted as your answer is a very different setup with the older Unibody systems.
의 공유
@danj Sorry about that, but the basic troubleshooting princle shall apply: make sure it's the camera by testing another assembly before proceeding the difficult part of replacing it.
의 공유
@wenchao - Apple makes testing on the there M series very difficult at the physical level. At best you have the onboard diagnostics.
Replacing is not really done, here the full display assembly is swapped out as the lid assembly is not easily opened and replacing the camera is just not done.the camera is serialize to the system.
의 공유
@danj "the camera is serialize to the system" does it mean the replacement camera wouldn't work?
I knew that a few iPhone componenets were binded to the system such as touch ID, which many people complained about. What good does it do for Apple?
의 공유
댓글 3개 더보기
댓글 달기
답변 3개
Start by resetting the NVRAM and SMC. If that doesn't help, then you know you have a hardware issue with the display. Replacing the camera itself on these models is not easily done. You would need to fully disassemble the display assembly and do some very delicate microsoldering. The more feasible approach is to replace the display assembly, but the displays on these can be pretty expensive. Here's a link to a display. Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Is this the original display that came with the system?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You might be better off just using an external web cam when necessary as the 'repair' to fix the possibly damaged camera is a nightmare of a job when it comes to removing the screen glass and all to get to the camera part...... Have you checked inside that all the cables are in place..... MacBook Pro 13" Two Thunderbolt Ports 2020 디스플레이 어셈블리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ronald León 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 46
전체 시간: 680
