주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
My screen show unable to activate
Can you suggest me some free website to recover it at zero cost . My phone is the iPhone X
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hey there, can you please explain your issue a little bit more? What issue are you experiencing with your device?
My iPhone does not support SIM cards
댓글 달기
답변 3개
가장 유용한 답변
Hey you need to connect it to iTunes or a iMac computer. It will either do one of 2 things reinstall OS or go into recovery and delete everything.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have done that also still not working . Actually i have factory reset in iphone then after factory reset it start showing unable to activate suggest me solution
댓글 달기
On the HELLO screen at the begining you see a little circle with a i in it on the bottom right of your screen, press on it> do you see a imei number? If not then you know why you can not activate the iphone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi @gyaanpudasai,
That doesn't seem very good does it.
If you're getting an "unable to activate" error, Apple says it's due to their servers being crowded or some garbage.
I think referring to this video is better (I'll add a link but i don't know how this platform runs with links so hopefully it stays).
Basically, there's a chance (Admittedly, very low) that someone took your serial number, cloned it to another device and activation locked it. Now, the video doesn't quite show the same error as yours so maybe it's not applicable but it's worth a watch:
https://www.youtube.com/watch?v=ifOifNBg...
However, depending on the country, your device could also be blacklisted if you did something to upset the big providers for data. Again, this is far beyond my scope but is a possibility.
Ignoring both of those then, can i just ask a few questions (as the people here have already done so thanks :)):
1) Did you turn your phone on to suddenly see it locked or did you try reset it?
2) Is this your device from purchase or a second hand one
3) Are you aware if your provider has blacklisted you for any reason?
4) Do you have any outstanding transactions with your previous provider? This can affect your ability to connect your phone to internet but maybe not activation, but still a possibility
5) Are you aware of any restrictions surrounding apple devices in your country (Don't have to mention which country if you don't wish to)
6) Finally, is the activation lock linked to someone else's account or yours? Check that since that is probably the most important thing to consider.
Hope this helps, and I am hoping we can get your phone back to working order as soon as possible.
All the best,
Nick
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gyaan Pudasai 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 295
