주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Renault Clio 자동차의 2세대 모델입니다. 1998년에 출시되었습니다.
My speedometer is not working
How do I fix my speedometer sensor.
Renault Clio 2
1.2
2005 model
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Speedos are either mechanical (old and I don't know when your model changed) of electrical.
For mechanical, the shaft is connected to a port on the transmission and run up to the back of the speedo.
For electrical, there is a sensor connected to the transmission housing. The wiring then runs to the speedo, either directly of via an ECU.
In either case, if it is not working something is open. Either the shaft has become disconnected, or a connector become loose or disconnected, a wire broken, or the speedo or sensor is malfunctioning.
1st - determine what type it is. Then proceed to check the possibilities.
2nd - for electrical, start with connectors and wires. If there is an OBD connector, you can see if the ECU is reporting a speed using an adapter and an app like Torque. If it is, then the ECU to speed circuit is suspect. If it isn't, then the Sensor to ECU circuit is suspect.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
LeJean McLaren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 760
