주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
간접적인 복사열, 대류 또는 열전도를 이용하는 방식이 아니라, 인덕션은 금속 용기의 자기적 성질을 이용해 자기장을 진동시켜 저항 가열 방식으로 음식을 조리합니다.
Chip out of cooktop
How can I repair a small chip broken of the smog induction cooktop?
It happened when a knife was dropped hitting the side.
Only small but noticeable
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Is the damage along the edge or near the coil areas? Can you post a few pics so we can see the damage clearly.
The chip is along the edge, l will try and send some photos
Sorry don’t know how to send photos 😔
@johnwagenaar We get that question a lot, so here's a page showing you how to add images to your question.
기존 질문에 이미지 추가하기
Thanks for the information, Jerry
댓글 달기
답변 1개
선택된 해법
If you have the chip and it fits cleanly in the space you could try a good cyanoacrylate glue like Loctite 1364076 Super Glue Easy Squeeze Gel. But it can’t be near the heated area as over time it will degrade.
If the chip is on the surface and/or you don’t have the loose piece you could use a black epoxy filler. First taping down the area to protect the rest of the area and limit creep of the area being filled. Keep in mind you may end up with a bump or still have a divot where the hole is. Using a knife to trim it may put the fill out and you don’t want to sand as the glass surface will then get scratched.
The bottom line it might be just better to accept the damage than trying to fix it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks Dan, l do not have the chip, l better leave it and avoid looking at it.
Thanks for your advice
댓글 달기
답변을 추가하세요
John Wagenaar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 67
전체 시간: 1,135
