주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 Apple 실리콘(M2 칩)과 13.3인치 Retina 디스플레이가 탑재된 MacBook Pro 13" 모델을 위한 수리 안내서입니다. 모델 번호는 A2338입니다. MacBook Air M2와 함께 2022년 7월 15일 WWDC 2022에서 처음 공개되었습니다.
BMU battery data cable connector broken
Hi there! I opened my laptop after I spilled a tiny amount of liquid in it… all good until I put everything back. Right at the end, by mistake, I pulled the cable from the BMU unit. One of the pins in the connector fell off. What are my options now? Please help …
이미지
이미지
이미지
이미지
Thank you…
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Is this just the cable that has broken? If so you can find them on numerous sites for example on iFixit. If it is the actual connector on the logic board then you'll have to source a new connector from somewhere or someone who has a donor unit, and then find a specialist to remove / solder on the replacement..... This may prove to be a little hard to find.....Good luck!
Replace the small flex cable that connects the battery daughter board to the logic board. 이미지
제품
MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
$16.99
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It’s the connector on the BMU. Thank you
댓글 달기
Yes the top part of the logic board connector (battery side) got pulled off. If you still have the piece you might be able to glue it back. But you will need to be very precise with the glue’s placement as it mustn’t interfere with the contacts or the latch. Replacing the connector is possible but it will take a hot air rework station and some skills to do it without making a bigger mess. Or, you just bite the bullet and replace the battery as the connector is on the battery side.
Either way I would remove the battery following this guide MacBook Pro 13" 2022 (M2) 배터리 교체 as the person with the needed tool and skills only needs the battery and the needed connector BMU Cable Connector it’s also available from other sources. Or just replace the battery the guide offers the part info.
A better view on the connector
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
@danj I think you have confused yourself? The part you say is broken is on the logic board, you then say to replace the battery? This all makes no sense to me.....
@livfe - yes it’s on a circuit board which is part of the battery. I’ve added a better image to my answer so you can see.
@danj Ahhh OK better now, cheaper & easier solution!
댓글 달기
답변을 추가하세요
Alexandru Gorgos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 25
전체 시간: 1,068
