주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rears break light doesn't turn on
Rear break light doesn't turn on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hello San.
We are going to need more information about what happened.
What happens when you press the brake?
This is most likely a blown fuse, faulty connector or a faulty break light sensor.
댓글 달기
답변 2개
가장 유용한 답변
@san38951 the very first thing you want to check all the fuses, the bulbs and the sockets for good connections. Next in line is your brake light switch. It is located under left side of dash, at the top of brake pedal. It's #3 in this image
이미지
Make sure that the plunger of the switch engages or disengage with the movement of the brake pedal. You can also use a multimeter or test light to see if the switch actually activates (closes contacts) when you depress the brake pedal. Because of the location of the switch it's a PITA to work on this but it is not to complicated. Of course, you always want to check all the fuses, the bulbs and the sockets for good connections.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
السلام عليكم
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
San 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 26
전체 시간: 391
