주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 5G 지원 Moto G는 6.5인치 720 x 1200 픽셀 90Hz LCD 디스플레이, MediaTek MT6833 칩셋, 그리고 광각 50MP 카메라, 매크로 카메라, 심도 카메라를 탑재하고 있습니다.
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kishore Kumar S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 370
