주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 5000ED로 식별할 수 있는 Nikon의 필름 및 슬라이드 스캐너입니다.
Scan head gradually gets more offset after each scan
I have an issue where the scanned image gets more and more out of frame. It gets worse after each frame and i get this error message in NIKON SCAN 4.0.
이미지
And where you can see the previewed image in NIKON SCAN 4.0.
이미지
Here is a reddit thread regarding the same question (from me)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This is a result of the Stepper motor being damaged and slipping on the shaft. All you have to do is simply replace the motor and it will work normally again.
It is not easy to get parts for this scanner anymore since there are no spare parts produced for it as of today, but apparently you can use stepper motors from the LS-40, LS-4000 works on this one too.
The original motor is marked NN-255, but you can also use motors marked NN-253.
Here is an ifixit guide to fix this issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
eirik dalhus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 464
