주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
{A1706 / EMC 3071}—2017년 6월에 출시된 이 13" MacBook Pro는 최대 3.5 GHz Core i7(Turbo Boost 최대 4.0 GHz)까지 지원하는 Kaby Lake 프로세서를 탑재하고 있습니다.
How to change the keycaps
I need to replace the keycaps on a old touch bar MacBook pro is there anything that I should know as I'm used to PC laptops and have never worked on a MacBook is there anything that I should know?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
These key caps are extremely easy to break. So going in prepared is key. :)
If you haven't taken a look at the internals of the key switch here's a picture that will probably help more than anything.
이미지
This image is a bit newer model, but the mechanism is largely the same. The key to damage free removal is to use something slim (like iFixit's Jimmy or an iSesamo) to get under the top edge of the key cap. That's the side with the clips, and the bottom edge has a little hinge in each corner that can take the posts on the key switch out too if you're not gentle.
There's also a Guide if you want a more step by step.
Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices. 이미지
제품
iSesamo Opening Tool
$10.99
Handy tool for opening electronics. 이미지
제품
Jimmy
$7.95
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Here is a good video that shows you how to replace the keys :)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
frey_code 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 284
