주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Nitro 5 AN515-43은 2019년에 출시된 가성비 게이밍 노트북입니다. 일반적으로 AMD Ryzen 모바일 프로세서와 NVIDIA GeForce GTX 또는 AMD Radeon RX 시리즈 그래픽을 탑재하고 있습니다.
Heating issue. Thinking of thermal paste it again?
My laptop is heating a lot. I'm thinking of changing my thermal paste and cleaning dust inside it also, or i should do something else, like expanding RAM.
Please help it's heating like a heater in cold season.
Thanks 😊
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Is the fan running and blowing air? I would start with that, and with cleaning the fan and heatsink it blows air through with some compressed air - try to prevent the fan from spinning while you clean it (clean it while it is turned off).
댓글 달기
답변 1개
Firstly, check the temperature of the CPU using Speccy.
Is it also hot when idle? If so, then some background process might be using the resources.
Check Task Manager process list sorting by CPU usage, to see what's using the CPU power.
Then clean your computer with some compressed air, maybe that'll be enough.
However if you haven't replaced the thermal paste in some years, it would be a good idea to do so.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aakash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 259
