주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일에 출시된 Apple의 2019년형 가장 크고 비싼 스마트폰으로, 6.5인치 OLED 디스플레이, 트리플 렌즈 카메라 시스템, 크게 개선된 배터리 사용 시간을 특징으로 합니다. iPhone XS Max의 후속 모델입니다.
iPhone turns off when removing case
Iphone 11 PRO MAX, turns off while removing covering case. Only on the top right corner of the phone, when looking from the screen facing me.
Is this a logic board issue or could it be a loose connector or something else?
For context, the battery was recently changed but not by me.
Whats my best course of action at this point?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It sounds like something may be shorting to ground, or some other electrical line when under pressure (assuming there is some flexing and struggling when removing the case). Most likely something is getting squished into something else it isn't supposed to be. Could be any number of things, but I will specifically call out that the main power rail for this phone does go to the display, so this could be as simple as the cable for the display is getting pinched, or was damaged.
If the battery was changed recently I would take it back to the person who did the repair and let them know since it sounds like this was something that started as a result of the repair.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Imre Kaljuvee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 179
