주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo가 스위치 시스템용으로 제작한 보다 전통적인 무선 비디오 게임 컨트롤러입니다. 모델 번호: HAC-013.
Botched Pro Controller Joystick Replacement - Is it salveable?
Hi everyone, I tried to replace the left joystick on my Nintendo Switch Pro Controller. Unfortunately, as the title says, I botched it. I managed to desolder most of the solder points for the joystick, but I still couldn't detach it.
In the process of trying to get any residual solder off the mounting pads, I partially ripped one of them. I think I need to get solder flux to try to get the remaining solder to flow to detach the joystick. However, I want to get the opinion of those more experienced to find out if I passed the point of no return before proceeding. Pictures are below.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
is it the bottom left in the photo
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Yes it is. You can see the torn pad on the right side of the mounting points in the bottom left of the picture.
@smoothbrain looks similar to the pins above so i would say its a ground pin and fine to connect both together, so the bottom pin to the 1 just above with either a jumper wire or solder blob which ever is easier for you to do
댓글 달기
답변을 추가하세요
smoothbrain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 339
