주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 3G의 향상된 버전으로, 더 빠른 처리 속도를 자랑합니다. 이 기기의 수리는 3G와 유사하며, 간단한 스크루드라이버와 도구만 있으면 됩니다. 모델 A1303 / 8, 16 또는 32GB 용량 / 검은색 또는 흰색 플라스틱 뒷면.
Boot Loop and battery not charging
Hi, I have used iphone 3GS model-A1303. I haven't used it for a long time and when i recently tried to turn it on it first displayed a battery flat icon and later it showed me the apple logo and then turned off. I charged it for 4hrs and still the same. So I enabled DFU mode and itunes recognized the device and when i tried to restore it posted that the device was previously in DFU mode now it has been restarted but my device is still in DFU mode. I suspect that this is a battery issue but before buying a new battery i need to make sure that the device is in working state. is there any way to find that or boot into device without battery. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This sounds strongly like a battery issue to me. In my experience. I have never known and iPhone to boot without a good battery unless you have the ability to connect a power supply directly to the logic board (via the battery connector).
Unfortunately, you'll likely have to get a good battery in it to get it to power on. The fact that it has responded to everything else though is good because it sounds like the system is functioning properly. Just needs a good power source.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@flannelist , ok i’ll try to get a new battery. Thanks for the help.
의
댓글 달기
답변을 추가하세요
4072_Prasanth 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 27
전체 시간: 253
